Updating TeamViewer on Windows XP PC
psteenkamp
Posts: 1 ✭
I have an instrument workstation PC running Windows XP. TeamViewer do not want to update or do a remote update to a newer version. The PC is currently on TeamViewer 9. How can I update this workstation PC?
Hello @psteenkamp,
you can find our supported operating systems here:
I have a quick note right from the article itself for you here:
- 📌 Note: we are no longer actively servicing Windows 2000, Windows XP, Windows Vista, or Windows Server 2000/2003/2008. You can continue using the last supported version of TeamViewer on those operating systems, but we are no longer providing updates or fixes which are specific to them. See this announcement for more details
Justin
German Community Moderator
