Problem with Teamviewer
MarkoAvramovski
MarkoAvramovski Posts: 2 ✭✭
edited June 2023 in General questions
When i tried to connect to users it gives me message that: Your license limits the max session duration to a partner, immediate reconnects are blocked. Please try later or upgrade your license.
WHat should i do? I am a first line support for TF Bank - Sweden and we have a license.
Thank you in advance,
BR,
Marko
  • Esther
    Hej Marko,
    Can you check whether the license is correctly activated on your account and that you are logged in?
    Thanks, Esther
  • MarkoAvramovski
    Yes, the license is valid. And it happened just shortly after i was connected at the user's machine. 3 months i was able to connect without a problem.
  • Esther
    Hi again MArko,
    Thanks for your feedback.
    Can you confirm that you were logged in to the account?
    Also: How many times did you try to connect?
    Thanks, Esther
