Cannot recover password
Passegua
Passegua Posts: 5 ✭✭
edited June 2021 in General questions
If I click on "forgot password" then I get:
"Activate the checkbox to prove that the operation is performed by humans."
But there is no such checkbox!!!
  • Joe_Oliver
    Joe_Oliver Posts: 1
    edited June 2021 Answer ✓
    I tried from both Google Chrome and MS Edge. Neither show a box you can check. I found a "reset password" link via a different thread here that had the appropriate checkbox to check and it was visible via Chrome. The issue seems to be with the password reset pop-up which is what users are presented when clicking "forgot password" The process is very difficult to navigate and should be fixed.
    Keywords: Password Reset, Forgot Password, Activate the checkbox to prove that the operation is performed by humans
    Hello @Passegua,
    Please try it from a different browser.
  • Joe_Oliver
    Joe_Oliver Posts: 1
    Thank you for the feedback. We have forwarded it to the dedicated team. 👍
