Connection on Windows Server 2012 R2 not working
PuntoExe
PuntoExe Posts: 1
edited June 2021 in General questions
Hello, I have installed the TeamViewer client on Windows Server 2012 R2, it does not connect ...
I see it online, I launch the connection it does not return errors but it does not connect.
Anyone with any ideas?
Thank you.
    Hello @PuntoExe,
    Thank you for reaching out.
    Our development team is aware of this issue. We are currently investigating the situation.
    Devices that are impacted are Windows Servers 2012R2 (Win_6.3.9600_S) that are not up-to-date.
    Updated OS are not impacted by this issue. Could you check if you can update your OS to the latest version?
    Let me know if this fixed the issue.
  • SAVJR1962
    SAVJR1962 Posts: 1
    I am currently have the same issue on 2 out of 3 of my 2012r2 servers. all 3 are 6.3 Build 9600. the 2 that fail are teamviewer host version 15.16.8 HC (32bit). and they will try to update but they fail. I can see them and in the TV console just will not connect.
    the system I can connect to the teamviewer host version 15.20.6 HC (32bit).
