Mass rollout TV14 with automatic license deployment
imssd
imssd Posts: 1
Hi there.
I am currently preparing the full version of TeamViewer 14.3.4730.0 for a mass rollout. I want to use the MSI deployment method and the deployment itself runs well. However, I am unable to roll out with a valid license. My test host just say that they are unlicensed ("Free version"), however, I have included a valid license key while exporting the configuration to Teamviewer_Settings.reg. I can even see the REG_BINARY data in "LicenseKeyAES"-key under HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\TeamViewer.
I have followed several documentation on this topic (eg. https://community.teamviewer.com/t5/Knowledge-Base/Mass-deployment-improvements/ta-p/39639 or https://community.teamviewer.com/t5/Knowledge-Base/Deployment-via-GPO-for-TeamViewer-Host-v13-2-Full-v14/ta-p/49088) to no avail.
Is there any "real" step-by-step guide that really covers every single detail on the process?
  • nmo99
    nmo99 Posts: 1
    Hey, have you been able to solve this somehow?
    I would need the same, but I always end up with a free-license, even if the deployed instance is assigned to a corporate account. It seems licensing mechanism changed a lot since we are using TV (since version 8, where this approach worked fine).
    So I also would need to mass deploy instances with valid licenses, but can't find a way for this.
    Hello @nmo99,
    Indeed, the deployment method has changed since version 8.
    Please find the current method below:
