้How to change license: PaidLicense to Business License
patkiti
patkiti Posts: 6 ✭✭
edited July 2021 in General questions
Dear Expert,
How to change PaidLicense to Business License.
Pat
    Hello @patkiti,
    PaidLicense and Business License are the same. There is no technical difference between them.
    What are you trying to achieve, do you have a specific issue related to this message?
  • patkiti
    patkiti Posts: 6 ✭✭
    Hello @JeanK ,
    I got the error message "Session limit reached" when A connection to B then C connect to B which different
    license id.
    I'm not sure this issue relates to PaidLicense status?
    edited July 2021
    These messages are not related.
    This means that someone is already using the channel of your license, as indicated in the message.
    If you don't think someone is using your license at the same time as you, please contact our customer support for investigation:
