Why are we being shut down??
YadinF
YadinF Posts: 3 ✭✭
Shutting off all versions prior to 15 is a major disruption to business and feels like a violation of the agreement. It's really unacceptable that we are being FORCED to stop using v14. We will most likely have to discontinue our use entirely because of this since we have to work around it now anyway so why bother trying to upgrade and pay more to a company that apparently is set on abusing customers.
  • JoshP
    Answer ✓
    Hello @YadinF
    Thanks for your post.
    We are not shutting down all versions prior to version 15.
    The only versions with planned deprecation are versions 8 - 10
    There is no planned deprecation of version 11 or higher at this time.
    Josh P.
    Senior Community Moderator
  • YadinF
    YadinF Posts: 3 ✭✭
    edited August 2021
    Then please explain why version 14 is not being allowed to run for more than 5 min with messages that we must upgrade to v15 and it won't work at all in a few weeks. The link we're taken to agrees with your statement of 10 and earlier, but the software is behaving differently, and all versions prior to 15 are being shut down.
  • JoshP
    Hello @YadinF
    Please verify that the device you are connecting to is not running version 8, 9, or 10. This can be found in Help -> About TeamViewer.
    If the remote device is running an older version, please update it to your latest version (version 14, if you have a version 14 license).
    As there is currently no planned deprecation of version 14 (nor 11, 12, or 13), should the issue persist please contact our support teams directly so they may look into the case.
    You can find local numbers here:
    Josh P.
  • YadinF
    YadinF Posts: 3 ✭✭
    We are using v14 as stated.
    Your support site does not appear to work. It either routes to a forum post that says to use the forums to get support, or it loops through asking repeatedly to give permission to something which makes no sense. The chat system is equally useless and also points to the forums.
  • JoshP
    Hello Yadin,
    As mentioned in our Knowledge Hub, if you are not logged in with a licensed account, you will be reverted to the community if you try to access the ticket portal:
    Please ensure the account you are using to log into the support portal is the one you activated the license to.
    More info on how to raise a ticket is here:
    You can also reach out to support over the phone, using the local numbers found on the support page
    Should the issue persist, feel free to DM the email address you are trying to access the support portal with so we may verify you are using the correct licensed account to access the support portal.
    Thanks in advance!
    Josh P.
  • Moe29
    Moe29 Posts: 3 ✭✭
    I have a v12 license , when I connect I get a notice to update to v15 , and that old versions will be discontinued on September 15th 2021
    Please advice if v12 will no longer be able to work after this date
  • dhs_hotelhelp
    I hear that teamviewer versions 5-10 are being discontinued sept 15th and a newer version of teamviewer is offered but it says nothing about teamviewer version 11.
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi, @dhs_hotelhelp,
    Thank you for posting on TeamViewer Community!
    TeamViewer v11 is NOT being deprecated -you may find out more information on https://community.teamviewer.com/English/discussion/comment/124573#Comment_124573 You can contact TeamViewer Support Team with local numbers here: https://www.TeamViewer.com/support
    Community Moderator/中文社区管理员
  • Akiho
    Akiho Posts: 1,216 Moderator
    edited October 2021
    Hi @Moe29,
    Thank you for contacting TeamViewer Community.
    Version 12 isn't subject to this matter, thus you can continue to use version 12.
    Regarding the update notification, please kindly to check both local and remote devices are using version 12. If any device using TeamViewer version 9 or 10, the connection won't established from 15.09.2021. Thus, please upgrade to version 12, and you can downloads version 12 from here.
    Hope this would be helpful.
    Best Regards,
    Akiho
    Japanese Community Moderator / コミュニティモデレーター
  • bassamuhammad
    When will TeamViewer 12 be discontinued and if it is discontinued, will we still be able to use this version to remotely access devices at remote sites?
