Old account
I am trying to login with my old account, which I haven't used for some time now, however I am always getting the following error, although I've changed the password several times:
"Your TeamViewer account needs to be upgraded and has been locked. Please use the “Forgot password” function in your client or go to https://login.teamviewer.com to initiate a password reset to unlock your account. After the password reset, please go to https://login.teamviewer.com and sign in to your account to complete the upgrade process."
Do you know how to resolve this issues, as password change doesn't help, I am afraid.
  • Justin
    Hello @Comm123,
    Have you tried resetting it? As I am not sure if you did. Please do if not.
    Tell me if it worked out.
    Justin
    German Community Moderator
  • Comm123
    Comm123 Posts: 2 ✭✭
    edited August 2021
    Hi @Justin ,
    Yep, I tried several times resetting the password, but no luck yet.
    I am still getting the same message that the account needs upgrading. Btw that's not for this account that I had to register to the community, but an old account that I have for a long time, but can't use anymore until it's being upgraded.
    Thanks.
