No Sound if I Connect from Windows 10 to a MacBook Pro
If have the following problem, if I connect from a Win10 Pro PC to my MacBookPro I get no sound.
I checked the options and the "sound and Musik" forwarding is activated on both team viewer clients in the options.
What can I do?
  • Justin
    edited August 2021
    Hello Pete777,
    Check out the comment from @Scotty to get further information:
    Justin
    German Community Moderator
  • GordonH
    GordonH Posts: 1
    TeamViewer 15.21.4 for Mac OS.
    I set up TeamViewer on both Macs, making sure that TeamViewer had access to the Microphone on both systems. I started a Remote Control session, and then started Audio and unmuted MY microphone. As soon as that was accomplished, the remote user could hear my voice.
    However, nothing I tried in the course of 45 minutes would allow me to hear sound from their microphone. TeamViewer has access to their microphone in Security & Privacy. I turned up the level for their microphone in Sound. I also made sure in TeamViewer, Preferences, that audio input was set to Built-In Microphone on their Mac.
    Likewise, in Speakers, both systems say Built-In Output.
    They can hear me, I can't hear any sound from their microphone. There is a possibility that their microphone is muted, but I can't find any control to unmute it.
    Thanks for looking
