Disable remote input and RDP connections
I started to black out the screen and disable remote input when I work from home on the desktop in the office. Since then I noticed whenever I opened a RDP connection, no key combinations seem to work.
When working on the host desktop, key combinations still work without a problem, but when trying it in a RDP connection it won't work.
I have looked for similar posts, but could not find one that matches my problem.
Is there a solution or workaround for this?
Jaimy
Hello @Jaimy_M,
Could please try changing the keyboard options in your RDP session by navigating to Local Resources → Keyboard from Apply Windows key combinations to On this computer.
Let me know if that solves it.
Justin
German Community Moderator
1
Hello @Jaimy_M,
Justin
Hi Justin,
That did solve it. Thank you for the quick response.
Jaimy
