Disable remote input and RDP connections
I started to black out the screen and disable remote input when I work from home on the desktop in the office. Since then I noticed whenever I opened a RDP connection, no key combinations seem to work.
When working on the host desktop, key combinations still work without a problem, but when trying it in a RDP connection it won't work.
I have looked for similar posts, but could not find one that matches my problem.
Is there a solution or workaround for this?
Jaimy
  • Justin
    Answer ✓
    Hello @Jaimy_M,
    Could please try changing the keyboard options in your RDP session by navigating to Local ResourcesKeyboard from Apply Windows key combinations to On this computer.
    Let me know if that solves it.
    Justin
    German Community Moderator
  • Justin
    Answer ✓
    Hello @Jaimy_M,
    Justin
  • Jaimy_M
    Jaimy_M Posts: 2 ✭✭
    Hi Justin,
    That did solve it. Thank you for the quick response.
    Jaimy
