How to configure quick support with preconfigure password
    Hello @iTware,
    Let me show you how to do it 😊
    1) Log into your Management Console
    2) Click on Design % Deploy and create a QuickSupport
    📌Note: If you QuickSupport is already created, click on the Edit icon of the QuickSupport
    3) Under Automatically add users to a group in your Contacts list, make sure the box is unticked
    4) Select Use a predefined password and set the password below.
    5) Click Save.
    You have now set up a QuickSupport with a predefined password. 😊
    Please let me know if it worked also for you!
    JeanK
    @iTware did you have time to test it?
    I am curious how it worked out for you. 😊
  • dave70
    dave70 Posts: 8 ✭✭
    HI JeanK--I am trying to set up a predefined password on my remote computer. I have read your process below. Can I access the management console on the remote computer to do this or doI have to go to the remote computer to set it up. It looks like this is a part of the process to access from the outside internet as I had asked you on an earlier question.
    //dave
    Hello @dave70,
    To set a (predefined) personal password on your remote computer, please access the TeamViewer options of the remote computer and follow the instructions here:
    📄 Personal password
    Let me know if you have any questions! I'll be happy to help you further.
    /JeanK
  • dave70
    dave70 Posts: 8 ✭✭
    edited November 2022
    HIJeanK-- Well I tried it two ways (change to perm password on remote computeer)
    Your knowledge base said design and deploy--> quick support--->password
    ---That did not work---
    THERE WAS NO QUICK SUPPORT BUTTON
    Then from the management console ..
    Profile--> Security---> change password
    IT SAID THE OLD PASSWORD WAS WRONG
    I rechecked the: [please do not post personal information] on the main screen and retyped it v e r y carefully and it said
    pleeeze help
    Also , do I need a perm password for remote access now that I have a license and am truly an official remote user?
    Hi Dave,
    Thank you for getting back.
    I thought you just wanted to set a predefined password on your remote device so you can connect to it.
    But now, I can see that you want to use QuickSupport.
    Could you please explain to me exactly what you want to achieve? I'll be able to help you then. 🙂
    /JeanK
