tv_x64.dll locked by VirtualBox
When upgrading Teamviewer i get this error:
2020-02-02-21-12-43 TVWriteFileEntry(): Warning! File C:\Program Files (x86)\TeamViewer\tv_x64.dll could not be moved to C:\Program Files (x86)\TeamViewer\Update\TVInstallTemp\TVFile17.bak.
I see tv_x64.dll is locked by VirtualBox:
29d4.2a60: supR3HardenedMonitor_LdrLoadDll: returns rcNt=0x0 hMod=00007ff97efe0000 'C:\Program Files (x86)\TeamViewer\tv_x64.dll'
Closing VirtualBox allows me to upgrade TeamViewer.  Any was to fix this?
Oracle Support said its a Teamview issue and the way that dll is signed.
  • Hi did you ever figure out a solution to this issue it keeps giving me major issues with my TeamViewer
    JeanK Posts: 5,794 Community Manager 🌍
    Hello @NinFanBoyFTW,
    Currently, there is no planned bug fix regarding this.
    I recommend opening a ticket and report the issue to our customer support directly.
    They will be able to forward it to R&D, as it seems to be an isolated issue.
    Open a ticket
