Android go e tw host
Goodmorning,
phone brand is Brondi
Model: Amico Smartphone XL
I just got the confirmation that TeamViewer is compatible with Android Go.
It seems to be an issue with this specific device/manufacturer, as Brondi is not part of our supported Android manufacturers.
Please check our supported manufacturers list here:
I hope this could at least answer the question...
Now i will write to manufacturer for take info about.
I give feedback when i receive @mail
All right - looking forward to hearing about your findings...🔍
This application with sms is very poor and apply the modify only on their sistem, not for android or TW.
I understand... thanks for clarifying!
I have a response.
The limitation is for android go over this hw.
Is not possible to "ON" manually.
Maybe TW could thinks about a "light" version? :)
Thank you for your update.
I will pass the message to our product team. 😊
I have the same problem on a Samsung A03 Core and according to the equipment list it is compatible with both TeamViewer Host and QS.
The error does not matter and the connection cannot be made because Android Go does not give overlay permissions on other applications, since the features to reduce battery use were removed.
