Android go e tw host
Badog2
Badog2 Posts: 5 ✭✭
I have smartphone with Android go.
When i had installed tw host this require function ti show over all apps.
But the phone return notify about this feature Is disabled because require top much resource.
Incompatibility with Android go or some workaround?
    Hello @Badog2,
    Thank you for posting.
    Let me check with our mobile product owner first.
    I will get back to you as soon as I hear any news.
    JeanK
  • Badog2
    Badog2 Posts: 5 ✭✭
    Goodmorning,
    phone brand is Brondi
    Model: Amico Smartphone XL
    I just got the confirmation that TeamViewer is compatible with Android Go.
    It seems to be an issue with this specific device/manufacturer, as Brondi is not part of our supported Android manufacturers.
    Please check our supported manufacturers list here:
    I hope this could at least answer the question...
    After some research on their website, I could find that this device has an integrated remote control feature.
    Have you tried it already? Maybe this will work for you...
  • Badog2
    Badog2 Posts: 5 ✭✭
    Now i will write to manufacturer for take info about.
    I give feedback when i receive @mail
    All right - looking forward to hearing about your findings...🔍
  • Badog2
    Badog2 Posts: 5 ✭✭
    This application with sms is very poor and apply the modify only on their sistem, not for android or TW.
    I understand... thanks for clarifying!
  • Badog2
    Badog2 Posts: 5 ✭✭
    I have a response.
    The limitation is for android go over this hw.
    Is not possible to "ON" manually.
    Maybe TW could thinks about a "light" version? :)
    Thank you for your update.
    I will pass the message to our product team. 😊
  • FMarino
    FMarino Posts: 1
    I have the same problem on a Samsung A03 Core and according to the equipment list it is compatible with both TeamViewer Host and QS.
    The error does not matter and the connection cannot be made because Android Go does not give overlay permissions on other applications, since the features to reduce battery use were removed.
