vpn not work
Hello ,
I have a problem with my VPN,
until yesterday all work,
today it does not work with any device , I stay in Tunisia
    Hello @mosefrenguelli,
    Just to be sure I understand your issue correctly.
    First, you enable your VPN on your device. And then, you start TeamViewer and connect to a remote device.
    And now, the connection can't be establish. Is this correct?
  • mosefrenguelli
    mosefrenguelli Posts: 3 ✭✭
    Yes it is correct ,
    with the last version , I have this message on the drive :
    Impossibile verificare la firma digitale dei driver richiesti per il dispositivo. È possibile che durante una modifica recente dell'hardware o del software sia stato installato un file danneggiato, con una firma non corretta o costituito da malware di origine sconosciuta. (Codice 52)
    but I don't understand why.... I download 64 bit version as my win7 and if I check my teamviewer... there is write 32-bit.......
    I uninstall all... also delete in the "regedit" (in a manual there is write this procedure) , but nothing
    I can confirm that TeamViewer is not supported with the use of a VPN.
    Please see more information about it here:
    I hope this could at least answer the question why it is not working properly...
  • mosefrenguelli
    I disagree, until the penultimate version, I had no problems, the vpn "Ping" and with "route add" I worked with more than seventy clients without problems. Now don't even "ping"
  • RichardGravener
    RichardGravener Posts: 1
    edited August 2022
    Hey there!
    My name is Richard Gravener. I use many VPNs like . [removed per Community Guidelines]
