How can I license my Teamviewer Portable Client version
hjjaeckel
Posts: 1 ✭
Hi Support,
where can I find the documentation: who can I license my Teamviewer Portable Client?
I read something needs to place into the ?.ini file ...
Thanks very much for your support & assistance.
Best regards
@lwm wrote:Hi @hjjaeckel
You must have a Premium license or up, and type your license number in your ".ini" file :
code=00-00000-000000-000000Better solution is to create TV Account and logint to TeamViewer Portable APP each time you need to use your license. In this way you do not need to set your License number in this INI file, but of course you can.
mLipok , AutoIt MVP1
