teamviewer GUI never comes up on RHEL8
I previously used teamviewer12 and 13 on RHEL7 as a client to reach other viewers.
I recently tried to use it on RHEL8 (8.5) and no window is coming up in my Windowing environment.
Here's what I see:
$ rpm -qa teamv\*
teamviewer-15.26.4-0.x86_64
Launching the GUI:
$ teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Starting network process (no daemon)
Network process already started (or error)
Launching TeamViewer GUI ...
$ echo $?
127
I used the same process (install the rpm, launch the viewer) on Fedora34 and there it worked (I accepted the EULA and TV came up) but on RHEL8 TV never presents a GUI.
In the TeamViewer Log, I see this:
Any ideas?
Got it working by installer libminizip.so.1
# rpm -qa minizip1.2\*
minizip1.2-1.2.11-24.el8.x86_64
IMHO the teamviewer rpm should require libminizip.so.1 to help with dependencies.
interesting: the teamviewer-suse rpm has modeled that requirement:
$ rpm -q --requires teamviewer-suse | grep mini
libminizip.so.1()(64bit)
