TeamViewer MULTIOUTPUTDEVICE is ruining my life
Every time I start up my computer there is no audio until I switch to a real audio device that is real and exists and has a purpose. I removed the malware installer ("TeamViewer") and it's still there! Permanently!! Whose idea was this?
  • JesseTV
    JesseTV Posts: 1 Staff member 🤠
    Answer ✓
    Hi!
    There has been an update on this.
    Please make sure that you have selected from the options "Send sound from this device" as shown in the picture below:
    This should fix the issue.
    If this does not work, please contact our support via support ticket or by calling us.
    -Jesse, TeamViewer Support
  • Unayung
    Unayung Posts: 1
    Hi. I was struggled with this issue for months. and I just googled this solution which works !
    Follow these steps:
    • Launch the Audio MIDI Setup (by default, this app is located in Applications > Utilities > Audio MIDI Setup)
    • Once open you'll see a list of devices on the left-hand side
    • Select the Belkin S52
    • Now click on the minus - button to remove it
    • Follow any prompts you may get
    and we select the TeamViewer Multioutput Device and click the minus as described above.
    and voila :D
    hope this works on your Mac too.
  • Schizm
    Schizm Posts: 2 ✭✭
    For me, this does not solve the issue. It removes it, but it then reappears again soon after. I even did reboots after following the steps above and removing it. My clients are a little upset as it is screwing up their output choices.
  • JesseTV
    Answer ✓
    Hi!
  • Evgeniy29
    Evgeniy29 Posts: 1
    "Please make sure that you have selected from the options "Send sound from this device" as shown in the picture below:"
    Mac mini M1 (2020) - macOS Monterey 12.5 - TeamViewer Host 15.32.3 H (08ee49d90b1)
    No such menu item!!! Please help!
