How to stop account assignment prompt
Thatian
Thatian Posts: 6 ✭✭
Hey, I'm a bit new to administrating teamviewer and been having the issue where Account Assignment prompt comes up after installing teamviewer host on a device.
Does anyone know how to stop it from prompting after installation? 😊
Currently I'm trying to get the host installed via SCCM, but if I do it manually or with sccm this prompt comes up 🤔
    Answer ✓
    Hello @Thatian,
    Silent installations are possible by using our supported mass deployment method.
    You'll find all relevant information here:
    📄 Mass deployment on Windows
    The script you can use is the following:
    msiexec.exe /i "%~dp0\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=xxxxxx APITOKEN=xxxxxx ASSIGNMENTOPTIONS="--reassign --alias %ComputerName%"
    Here, the /qn parameter is the one allowing the silent installation.
    Let me know how this goes!
    /JeanK
    Answer ✓
    Hello @Thatian,
    /JeanK
  • Thatian
    Thatian Posts: 6 ✭✭
    Hi JeanK,
    Thanks a lot for your reply! 😊
    After you response I might've found the issue then, I tried comparing your line to what I was currently using and I was missing the API Token, guess it's probably more important than I expected 😅But I also had a settings file in mine, can I delete that from the script? We're not really customizing any settings and should run stock and just work 😊
    My Current script:
    msiexec /i "TeamViewer_Host.msi" /qb CUSTOMCONFIGID=xxxxxxx SETTINGSFILE="\\path\to\tvopt\TeamViewer_Settings2.tvopt" ASSIGNMENTOPTIONS=" --reassign --alias %ComputerName%"
    I'll be adding APITOKEN later today, as soon our owner of teamviewer allows me to enable it 😁
    Happy to hear about your findings! Indeed, the API token is very important! 😊
    If you are not using the settingsfile at all, I would remove it totally from the script.
    Also, I would recommend adding the Easy Access setting. Please check what Easy Access is about here:
    📄 Easy Access
    With Easy Access added, the script would look like this:
    msiexec.exe /i "%~dp0\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=xxxxxx APITOKEN=xxxxxx ASSIGNMENTOPTIONS="--reassign --alias %ComputerName% --grant-easy-access"
  • Thatian
    Thatian Posts: 6 ✭✭
    Hi JeanK,
    Just wanted to thank you for you're help. We've just implemented it with APITOKEN and without --grant-easy-access which gives us the output we've wanted! 😊I can thank you enough for you assistantace 😀
    I am very happy we could resolve the issue. That was real teamwork! 😎
    I hope to see you soon posting in the Community-
    /JeanK
