My connection Partner is running an old version and there is no one in front of it?
I have tried to install all the old versions on my windows(11,12,13 and 14) and I could not connect to my connection partner that shows a message "you are running an old version which is out of date".
I know that I need to check for a new version for my partner and upadte the current version but there is no one in front the computer there.
Is there any other solution here?
Thank you.
  • metro
    metro Posts: 1
    Did you find a solution?
    Gr
    Marc
    JeanK Posts: 6,435 Community Manager 🌍
    Hello @Riem59 and @metro,
    It is currently not possible to do this operation remotely.
    Someone will need to go on the other side and update the client.
    /JeanK
