quick support in iPhone
maozgl
maozgl Posts: 2 ✭✭
Why is quick support is disconnecting after a few seconds and in android it's working ok when I give support for users for my windows 10 computer, with the proper license?
    Hello @maozgl,
    Just to make sure I understand it correclty.
    You are working with a windows 10 PC and you are connecting to Android devices.
    You can establish the connection but the connection stops after a few seconds. Is this correct?
  • maozgl
    maozgl Posts: 2 ✭✭
    the problem happens only when working with windows 10 pc and connecting to iphone.
    when connecting to android from the pc there is no problem .
    Have you tried to reinstall the QuickSupport app on the iPhone?
  • focusp
    focusp Posts: 2 ✭✭
    Thanks, reinstalling the QS app fixed it for me too on an iPhone.
    @focusp I am glad to hear this! 🚀
    /JeanK
