Anybody solve the no gui problem on linux
JHPArizona
JHPArizona Posts: 4 ✭✭
edited February 2022 in Linux only
I am running updated FC34 system. I have uninstalled / reinstalled several times as a possible solution. What I get is the following:
/teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
chmod: changing permissions of '/opt/teamviewer/config': Operation not permitted
chmod: changing permissions of '/opt/teamviewer/logfiles': Operation not permitted
Launching TeamViewer ...
Starting network process (no daemon)
Network process started (162965)
Launching TeamViewer GUI ...
[teamviewer]$
Terminal returns to a command prompt and no gui is displayed
top shows teamviewer appears to be running:
PR NI VIRT   RES   SHR   S %CPU %MEM TIME+    COMMAND
20 0  936652 13028 11400 S 0.0  0.4  0:01.11  /opt/teamviewer/tv_bin/teamviewerd -n -f
tv-setup /checklibs returns:
All library dependencies (*.so) seem to be satisfied!
   QtQuickControls seems to be installed
Any thoughts?
  • JHPArizona
    Nobody has run into this and resolved it?
  • JHPArizona
    I guess not 😫
    Good thing I have access to more than one operating system.
  • JHPArizona
    Note: a launch for Team Viewer is not in the application menu.
  • chpo
    chpo Posts: 1
    If it helps;
    I am having the same issue with ubuntu / lxde 18.04 , teamviewer up to date 15.28.8 (DEB), where the gui will not open AND i can check the deamon is running, and cannot connect remotely. It used to work and I do not know when it stopped working.
    I have a separate a seaprate desktop with standard (default) interface (I cannot keep track of al the name changes) ubuntu 20.04, teamviewer up to date 15.28.8 (DEB). I can connect remotely to that machine, and can open the gui locally (on that machine) as well.
