Send ctrl+alt+del is grayed out
When I remote into a client's Windows 2003 server, the "Send Ctrl+Alt+Del" button is grayed out.  Any idea why?
  • HugoC
    HugoC Posts: 1
    Having the same issue...
    I can move the pointer/mouse remotely, but clicks are not registered, same as any keystrokes at remote machine. Please help...
  • AlenaC
    AlenaC Posts: 932 Moderator
    Hi @HugoC
    first of all welcome to our Community :)
    Since you are answering a very old post, please allow me to first ask you which TeamViewer version are you using on both devices and your operating systems. Please check here the latest available version for your operating systems:
    👉️Supported operating systems
    As a second step, please also check the settings (remote control) in your TeamViewer client (gear icon ⚙️--> advanced --> advanced settings for connections to this computer).
    Let us know if this helps.
    Best, Alena
