Copy Paste Errors
sshah254
Posts: 1 ✭
I have Windows 10.0.19044.1706 running under VMware Fusion 12.2.3 on a Intel MacBook Pro running macOS Monterey 12.3.1
TeamViewer 15.29.4 is installed on this Mac.
I have a M1 MacBook Pro running the same versions of macOS and TV.
If I copy paste data from Win10 to M1 Mac, it is all garbled (it is just code, pure text).
If I copy paste from Win10 to the Intel Mac (host), and from there to M1 Mac, it copy pastes fine.
What gives? Why do I get garbled data?
Seems like this just started happening "recently". Before everything used to work fine.
Sandip
no one has the answer? I also had the same problem and until now, it's still not solved
