Operating system: Windows
Version: 15.27.3
Release date: 2022-02-22
Hello all,
To return to the way it worked before, you need to disable the setting in the options as shown below:
Hope this could help.
/JeanK
This function is too difficult to use, I hope to restore the previous
"New remote session windows now open their previous positions on your screen"
No, they don't. EVERY window opens up at the LATEST closed windows position and SIZE meaning that I have to resize EVERY newly opened window if the resolution is different than the latest one. This is not funny and NOT a new feature rather a nasty BUG.
Any updates on this??? We need this fixed ASAP
When are we getting the ability to upgrade from 32-Bit to 64-Bit like any other software??
It's crucial that we can just install 64-bit over 32-bit which should just upgrade fine!
Uninstalling 32-bit and installing 64-bit manually on thousands of machines in just 1 company is just not funny... or professional..
