I am using Teamviewer 12 since the last few days unable to connect to remote station.
Getting the following error:
No connection to partner.
Partner did not connect to router.
Error code:WaitforConnectFailed
Please advice if you have any solutions
Hello @Vianney,
The "Partner did not connect to router" is a result of network-related issues. Meaning that something is not working while trying to connect.
Please check on your remote computer if it's connected to the internet. Also, please check your power options, so the remote computer is not entering hibernate.
Another option you should check is if your antivirus or your firewall are allowing in- and outcoming connections.
Let me know if those fixed your problem.
Justin
German Community Moderator
Why can I connect to a remote computer in my list by Windows Remote Desktop and it not connect with Commercial licensed version 15 of Teamviewer? It continues to give me the same errors as above: No connection to partner! Partner did not connect to router. Error Code: WaitforConnectFailed
