Several computer reboot questions
bushyiii
bushyiii Posts: 4 ✭✭
Do the Teamviewer ID and Password remain constant with reboots?
Does the target computer always listen for an incoming connection?
I want to setup teamviewer in support of an out of State parent. I need to know if they have to start Teamviewer every time they need me to log in to help and if it requires a new password as well.
    Hello @bushyiii,
    Yes, the TeamViewer ID won't change after a reboot.
    If you want the target computer to always be ready for an incoming connection, the best way is to install the TeamViewer Host.
    You can find the download page here: https://www.teamviewer.com/en/download/
    💡 The Host will always be running in the background and ready to receive an incoming connection.
    For your connections, we recommend using Easy Access.
    Let me know if this could help you!
    /JeanK
