Same version yet they wont connect
giojohn
giojohn Posts: 13 ✭✭
team viewer are of the same version yet it tells me its not both are running 12.0.259192
    edited June 2022
    Hello @giojohn,
    Good to see you posting again!
    If both are running 12.0.259192 it and it still gives you an error message, we can maybe call it a bug.
    I would recommend reinstalling version 12.0.259192 on both devices and checking if it works.
    Let me know if this worked.
    /JeanK
  • giojohn
    edited July 2022
    Both devices have the SAME VERSION!!!!! Why do I have to troubleshoot this **bleep**? Both have 12.0.259192. Both machines are TRUSTED. Yes I have uninstalled it and re installed. Tell me something NEW
  • giojohn
    DIDN'T WORK Like this IT guy never thought of that first.
    Are you getting a specific error message?
    If yes, could you share a screenshot of it?
  • giojohn
    Uninstalled on both devices. re installed same version for BOTH
  • giojohn
    I get this either direction/connection, PC to MAC MAC to PC, PC to PC ALL with the same version. Oh! they can all connect to the host just not to this new laptop.
    Hi @giojohn,
    💡 I think I found the solution to your problem.
    As you using TeamViewer 12, the activation process was different back then.
    You need to activate locally your license on the local or on the remote computer (but at least on one of them).
    To activate locally your license on your device, please follow this procedure:
    1. Open TeamViewer 12
    2. Go to Extras
    3. Click on Activate license
    4. Enter the license key which is on your TeamViewer invoice
    5. Click OK.
    Now, your license is activated on your device, and the version out-of-date message should be gone. ✔
    Let me know if this fixed the issue.
    /JeanK
  • giojohn
     2019 is when i bought this service. For the life of me I can't find my registration key/email with that info
    Your license key is crucial information you absolutely need to have to guarantee a well-functioning TeamViewer 12 license.
    I recommend calling our customer support and requesting a copy of your invoice, so you can activate your license as I explained above.
    /JeanK
