TeamViewer crashes remote PC
Gardener
Gardener Posts: 1 Newbie
edited July 21 in Remote Access License
When I used the free version I had no problems but since buying a license, logging in to my Windows 10 laptop from another PC crashes the remote computer (my laptop). From TeamViewer it looks like the remote disconnected but when I get home I find it shut down.
Thanks!
  • Valeria2
    Valeria2 Posts: 212 Moderator
    Hello @Gardener
    Congratulations for your first post.😃
    To use TeamViewer correctly, I suggest you verify that you have logged in with your credentials (e-mail and password) in the access option in the upper right-hand corner of the program.
    Another step is to make sure that TeamViewer is open on the remote in order to receive the connection.
    💡Finally I recommend you contact our technical support department for more direct assistance through a ticket, HERE we explain you how to open it.
    For further information don´t hesitate to reach us again.
    Valeria
    Spanish Community Moderator
    Moderadora de la Comunidad en Español
