Teamviewer vs Teamviewer Host
I'm a frequent traveller and I would like to access my home desktop. I need an unattended remote access which is Teamviewer Host, however it seems that the normal version does the same task too.
What's the difference between Teamviewer and it's Host version?
I need a solution that allows me to access my desktop anytime (auto start-up on boot) without needing somebody to start the App upon reboot. Which should I use?
If I should be using the Host version, which App do I use for remote access?
  • tsolignani
    tsolignani Posts: 6 ✭✭
    Thank you for clarification.
    In my mac, I would like to have the app as the host version, but sometimes I need the teamviewer client to access a smartphone of mine.
    Matter is that if I install the other version of Teamviewer, the complete one, the host one gets automatically removed.
    Then I have to keep the Teamviewer version running and in the dock all the time and I don't like it, both aestetically and for it takes more resources.
    Do you know if there is a way yo keep them both or install, beside the host one, a client version which could cohexist with the host?
    Thank you.
