Remote Access without Confirmation or Password
OneshotStott
OneshotStott Posts: 1
I see my same question has been asked several times, the same solution of setting everything to 'Full Access' does not work for me, I have both my laptop and my home server set to Easy Access, connected to my TeamViewer account and yet it always either request a password or confirmation when I'm trying to connect for remote control via my laptop.
I have read so many forums queries on this and they all tell you to set it up how i currently have it set up, so it doesn't make sense to me why it doesn't function properly?
This obviously renders this software useless, does anyone have any solutions for this?
  • .Carol.fg.
    .Carol.fg. Posts: 1,083 Moderator
    Hello @OneshotStott ,
    Welcome to TeamViewer Community!
    By the description you provided, I believe the devices may have further settings interfering with the easy access.
    Could you please double check on both devices how the Advanced Options are showing?
    👉 Please make sure that the Access Control is set as Full Access.
    Let me know if it works, or if further assistance is needed. 😊🍀
    Carol
  • dmccorkle911
    dmccorkle911 Posts: 1
    It does not work because it still requires consent.
  • .Carol.fg.
    Thanks for your reply!
    Interesting... 🤔
    If TeamViewer is still asking for consent for the remote connection after both devices (your device and partner's device) are configured with Full Access to the Advanced Options in both:
    • Advanced settings for connection to this computer.
    • Advanced settings for connection to other computers.
    Then I would say that the remote connection itself may be starting with the wrong button...
    👉 How exactly do you start the remote session?
    Please note that if you're using the Computers & Contacts list, and instead of double-clicking the device, you select the Remote control prompt for confirmation, your partner will need to allow the connection on their side even if you have easy access.
    I hope this information can help!
    Let me know if you need further assistance. 🙋‍♀️
    Carol
