Help
I have a Samsung phone and need to use teamviewer to connect to my chromebook is this possible . I keep getting a message
This partner doesn't accept incoming connections
  • Ying_Q
    Ying_Q Posts: 2,601 Moderator
    Hello @RayReddington1966,
    Thank you for reaching out to us in TeamViewer Community and congrats on your first post! 🙌
    Can you kindly check the setting on the remote device which is the Chromebook please.
    The path is TeamViewer - GearWheel (⚙) - Advanced - Advanced settings for connections to this computer - Access Control - Full Access.
    Can you kindly check and try again for remote connections. Hope it would work for you this time!
    Community Moderator/中文社区管理员
