Teaviewer keeps logging out of account
2»
  • thesourcehim
    thesourcehim Posts: 4 ✭✭
    I have the same problem with 15.20.6 linux version.
  • Duy194
    Duy194 Posts: 1
    I recently installed on my new PC and had same issue
    After trying to connect again couple times, teamviewer is shutdown by itself.
    Can anyone advise what to do?
  • BastianAndre
    Also experiencing this loggout on Ubuntu 20.04 with TeamViewer Host 15.27.3
    Still no update on this? :(
  • Hanuboy
    Hanuboy Posts: 1
    edited March 2022
    Same here. It's been several years with the same problem. Mac OS Mojave. TeamViewer Version: 15.27.3
  • Thales
    Thales Posts: 1
    Same here. I'm still using 13.2.36224. This problem has bothering me for many years...
  • JSS51
    JSS51 Posts: 4 ✭✭
    I as well. I purchased a new Dell Windows 11 Home Edition Laptop and with version 15.40.8 of Teamviewer installed it signs out after 1 -7 days normally. My other older windows laptop with TV 15.40.8 run well.
    At times when I go to connect to this device via Team Viewer it shows Teamviewer is up and running but I also get this error when trying to connect to this new Dell Windows 11 Home Edition Laptop:
    Error No Connection to Partner! Partner did not connect to router. Error Code WaitforConnectfailed
  • xippo
    xippo Posts: 1
    Hello guys,
    I maybe found out how to "fix it"
    First you need to use Server ID (right-click on icon -> About TV)
    Second you need to set personal password. (Setting -> Advanced -> personal password)
    Hope it helps
  • Kryptekk
    Kryptekk Posts: 7 ✭✭
    i'm on 15.52.3 and all 10 of my machines are doing this. most of them are mac...but when i go work in the office trying to connect back to another sites machines...they've already signed out and even though they show up in the list, i can no longer access them. Someone from the other side has to sign into the machine, sign into teamviewer and then i'm able to re-control the machine. It's been happening with almost all V15 versions for me.
