user management
I am currently looking for a solution, not sure if teamviewer can give me the followings:
I have a workstation (win10) to let a few users to login with teamviewer at the same time to do their daily operations. But I want each user to have their own username/password to remote the workstation. In addition, each user can only see his own desktop and folders/files and can't see and modify any folders/files created by other users.
Thank you.
    Answer ✓
    Hello @edisonwang66,
    Congrats on your first post!
    I'll start with the first question. 🙂 Yes, you can set up a password for each user.
    The feature is called Manage additional passwords... and can be found under TeamViewer Options (⚙)Advanced settingsPersonal password.
    Regarding your second question, multiple users can't connect simultaneously to a computer simultaneously and see only their desktop and folders/files and can't see and modify any folders/files created by other users. Unfortunately. 🤔
    I hope my answer could help!
    /JeanK
    Answer ✓
    /JeanK
  • edisonwang66
    edisonwang66 Posts: 2 ✭✭
    All clear, thank you @JeanK
    You're welcome!
    It was nice to chat with you - I hope to see you around soon. 🙌
    /JeanK
