Stuck in landscape mode inside portrait view
ztyo
ztyo Posts: 8 ✭✭
edited September 2022 in Mobile
I'm stuck here (see screenshot) - any suggestions? I tried turning my phone, and I tried restarting teamviewer.
What I'm doing: remote controlling my android phone. Or trying to, anyways.
  • ztyo
    ztyo Posts: 8 ✭✭
    Bump - This is unusable for me now. I'm stuck in landscape mode inside of a portrait view See screenshot in first post.
    Hi @ztyo,
    Good to see you posting again!
    Just a quick question - did you set the orientation on "auto-rotate" or did you enforce it?
    /JeanK
  • ztyo
    ztyo Posts: 8 ✭✭
    Hi JeanK- thanks. You mean on my phone settings? I tried doing both. No change, either way.
    If you mean in the TeamViewer settings, I can't find where to set that.
    Hi @ztyo,
    Yes, I meant on your phone settings. Hmm, that's strange.
    Could you tell me what is the exact device (brand + model) you are using?
  • ztyo
    ztyo Posts: 8 ✭✭
    It's an LG Stylo 4. Android version 8.1.
    Thank you - I've checked, and there are no specific issue reports regarding this device.
    I would suggest reinstalling the QuickSupport/Host on your mobile device.
