No trusted device confirmation email
rhickman
rhickman Posts: 6 ✭✭
We're having an issue with adding devices for  unattended access. When adding a computer to computers & contacts the process :
"To ensure the continued security of your account, you need to first confirm this device is a trusted device.
We have sent you a confirmation email containing a device authorization link..."
does not succeed in sending the message. We've not been able to recieve the message even though it used to work,
  • hej1
    hej1 Posts: 4
    I have the same problem with my original account (this is just setup to be able to write this.)
    I can non use the software, the management console och the forum.
    And not activate two-way activation then I can not log in...
    Please advice!
    / Hans
    ps. I have started a new post with this poblem.
  • Mitch_childs2020
    Why am I getting constant stream of requests to add a trusted device when they have already been trusted "Yes, trust this device" and they show up in the management console?
    Hello @Mitch_childs2020,
    If this issue keeps occurring, please open a ticket so our engineers can investigate:
  • MichaelCarper
    I have the same problem. Has this ever been solved?
    Mike
    HRD Software
  • tflora
    tflora Posts: 4 ✭✭
    Having the same problem. Why has what used to be a very simple product turned into such a convoluted mess?
    Hello @tflora,
    Just wondering - are you using your browser in incognito mode?
    If yes, this would explain why the trusted devices are not saved.
    /JeanK
  • Alan1250
    Alan1250 Posts: 2 ✭✭
    Same problem here. I received them on a couple of devices, but then nothing. Still searching for a solution.
  • Alan1250
    Having same problem from Android app. So no incognito involved.
