Debian repository has errors again
gene_wood
gene_wood Posts: 2 Newbie
edited September 2022 in Linux only
As happened last year in this post ( https://community.teamviewer.com/English/discussion/117832/debian-repository-has-errors ), the debian packages created about 11 hours ago are corrupt in some way. Doing an "apt update" on Ubuntu 18.04 returns this error on the Teamviewer Packages.gz file.
Could someone in Teamviewer operations team update these files to fix this error?
Err:29 http://linux.teamviewer.com/deb stable/main amd64 Packages
  File has unexpected size (4814 != 5052). Mirror sync in progress? [IP: xxx]
  Hashes of expected file:
   - Filesize:5052 [weak]
   - SHA256: xxx
   - SHA1: xxx [weak]
   - MD5Sum: xxx [weak]
  Release file created at: Tue, 27 Sep 2022 06:45:22 +0000
E: Failed to fetch http://linux.teamviewer.com/deb/dists/stable/main/binary-amd64/Packages.gz  File has unexpected size (4814 != 5052). Mirror sync in progress? [IP: xxx]
    - SHA256: xxx
    - SHA1: xxx [weak]
E: Some index files failed to download. They have been ignored, or old ones used instead.
