VPN Quick Support
celdauray
celdauray Posts: 1
I have a corporate teamviewer licence and I am providing QuickSupport to the computer I need to connect to.
However I need to use the VPN feature and it's grayed out on my computed like the QuickSupport client doesn't seems to support this feature.... On my computer the driver is installed, but on the QuickSupport client I don't see the option to install it...
Do I need to install the full version instead of QuickSupport on the other end?
JP
    Hello @celdauray
    Solution : Indeed, you will need a full version on the other side.
    You will find all the information you need in our Knowledge Base article here: About TeamViewer VPN
  • sbaum
    sbaum Posts: 1
    @JeanK is there now the possibility to activate it, or is still the full version required?
    Regards, Sebastian
    Hello @sbaum,
    Welcome to the TeamViewer Community! 🚀
    There is still the full version required in this case, and I think this will not change anytime soon, as the VPN driver requires the TeamViewer service to be running (with QuickSupport, no TeamViewer service is running in the background).
    I hope this could at least answer your question. 🙂
    /JeanK
