Run check for patches on boot
thebrilliantdog
thebrilliantdog Posts: 2 ✭✭
Is it possible for a check to be run on boot (Windows 10) for available patches and then for them to be applied?
I know PowerShell scripts can be run, but I am unsure if there are commands within PowerShell to run any of the TeamViewer patch management features?
    Hi @thebrilliantdog,
    Great to see you posting for the first time! 🚀
    Our best practice to keep your TeamViewer clients up to date is to run the auto-date via TeamViewer policy.
    You'll find how to create policies here: Create a settings policy
    Important here is that you create a policy with the parameter Check for new version and that you enforce it on all your devices.
    You'll find all your policies here and how to apply policies on your devices here: Assign a settings policy to your devices
    Let me know if you have any questions! I'll be happy to help you further.
    /JeanK
  • thebrilliantdog
    Apologies, I was not particularly clear here. I want to check on boot for available patches from the asset management system, ie chrome, Teams etc. Then apply the patches to the machine.
