Will not connect Windows 10 PC to Mac
I have a Widows 10 PC with latest version of TeamViewer tryin to connect to Mac (High Sierra) with latest version of TeamViewer.  I can connect the Macto the Windows PC, But when I try to connect to te Mac from Windows, it just stays in "connecting".  Any ideas?
    Hello @StanBeck,
    I recommend you to restart the TeamViewer service on your Windows device.
    -Execute Run, type services.msc and press OK
    -Now find TeamViewer, and restart it by doing a right click.
    Then, restart the TeamViewer application and try to connect again to the Mac.
  • d291173
    Hi @JeanK
    I'm also having this problem, but I found that restarting the TeamViewer service did not help. Are you able to suggest anything else I might try?
  • StanBeck
    I restarted both the Windows 10 PC and the Mac multiple times.  It just then started working.  I do not know if there is a sequence it has to be done in or if they have to restart in a certain sequence.  Sorry I cannot be more help.
    Stan
    @d291173 Have you tried to restart your devices completely as @StanBeck suggested?
  • Helen199
    @JeanK wrote:
    TellDunkin
    Wow, it’s very helpful blog for comments. Will try to follow all these stuff!
  • perlin
    perlin Posts: 2 ✭✭
    I too can TV from my MAC to Windows, but not from Windows to MAC. The status is stuck on "connecting...". When I reboot both machines, I do see the MAC login screen on TV session, but then stuck at "connecting.."
    Restarting the service did not resolve the issue.
  • perlin
    perlin Posts: 2 ✭✭
    I use Win 10 & Monterrey.
