[Windows] v15.38.3
JeanK
edited February 2023 in TeamViewer Remote
Operating system: Windows
Version: 15.38.3
Release date: 2023-01-24
Bugfixes
  • Fixed a file transfer bug that prevented a partially-transferred file from resuming after the transfer was canceled due to connection issues.
  • RaphaelBM
    RaphaelBM Posts: 37 ✭✭
    edited January 2023
    I cannot get the latest update. It is in the blog as [Windows] v15.38.3
    [Windows] v15.38.3
    JeanK Posts: 6,508 Community Manager 🌍
    January 24 edited January 24
    Version: 15.38.3
  • RaphaelBM
    Operating System - Windows 10 Home (x64) Version 22H2 (build 19045.2486)
    System Model - TOSHIBA SATELLITE C850D-12L PSCC2E-02L00JEN
    Hi @RaphaelBM,
    as always, please wait a few hours until the update is globally rolled out.
    You should be able to get it by now.
    /JeanK
  • RaphaelBM
    I waited 2 days. YES the update worked. Thx for the help.
    Raphael
  • AlexFogerty
    AlexFogerty Posts: 35 ✭✭
    Hi Jean,
    We installed the 15.38.3 version and we now have multiple computers that are no longer displaying a ID number or password with no internet connection in the bottom left. Rolling back to the previous version 15.37.8 fixes the issue.
    I note that when we change the proxy settings from "Automatically detect settings (recommended)" to "No proxy" we then get a green "ready to connect (secure connection)" message at the bottom left, but the ID and the password stilll remains blank and we can't make a connection.
    I opened a ticket with TeamViewer Support but they just said to do a clean uninstall and reinstall, which didn't help.
    Hi @AlexFogerty,
    Sorry for the late reply.
    Did you try to update to 15.39.5 and see if it works as expected?
    /JeanK
