How to get real unattended access to Ubuntu 22LTS?
Hi folks,
I have the problem that I could not suppress a final confirmation to "Select monitor to share":
Seems like it comes from Ubuntu.
I have done already the steps form: (Grant easy access or personal password)
So I can access easily without a password. ((But it needs somebody in front of the PC to click at the confirmation above, what is not possible if I'm not at home and want to control my PC))
The option: Options > Security > Unattended access
Seems not available in the current Version: 15
Also I guess that the Confirmation comes from Ubuntu.
I already allowed "Remote Desktop" at: Settings>Sharing
((Even if it normally is for integrated VNC-Server.))
KR Michael
  • .Carol.fg.
    .Carol.fg. Posts: 1,083 Moderator
    Hello @MichaelFranziskus 😃
    Welcome to the TeamViewer Community! 🎉
    • Could you double-check if you have Wayland enabled?
    The TeamViewer version 15.29.4 brought improvements for compatibility with Wayland; however, unattended access is still not possible with it.
    👉 You would need to disable Wayland and use your Ubuntu 22 with Xorg.
    For more details, please see the discussion:
    I hope this information helps!
    Let me know if you have any further questions. 😊
    Carol 👩🏻‍🦰🌷
  • MichaelFranziskus
    MichaelFranziskus Posts: 3 ✭✭
    Hi Carol,
    thanks for your answer.
    I've seen the hint to use the beta of wayland.
    But there are much modules missing so I havn't clicked it.
  • cmbdakri
    cmbdakri Posts: 5 ✭✭
    i disabled wayland and still get the sharing confirmation, please how to do thath away
  • cmbdakri
    it is this screen i still get over and over and i tried like anything, does anybody have tips
  • micheguidi
    micheguidi Posts: 1
    @cmbdakri
    sudo nano /etc/gdm3/custom.conf
    make sure you have
    WaylandEnable=false (without the #)
    sudo reboot systemctl restart gdm3
    sudo reboot now
    it should be fixed
  • Scorpy80
    Scorpy80 Posts: 1
    i have the same issue and confirm the issue comes icw Wayland
    @micheguidi
    thanks this worked, easy access is now working by design 👍🏼
  • sluiswacht
    sluiswacht Posts: 1
    edited February 2023
    I had the same problem : could not get unattended access due to "select monitor" dialog window popping up on the remote machine.
    Disabling Wayland solved that but created another issue :(
    I have a couple of PTZ IP camera's on the remote machine, viewed by rtsp in VLC. But that apparently requires Wayland enabled on that machine, W/O Wayland VLC can not open the rtsp streams.
    Unplugging 2 of 3 monitors leaves a popup with the only remaining monitor check marked for sharing :(
