remote control authorization
marcusus
until I devise a better method to shut down my windows 7 box from a samsung tablet I use teamviewer.
Upon launching, the UI gives me an ID + password and that's okay.
What's not okay is that most of the times, when logging FROM my tablet to my windows box, teamviewer changes the password.. so I have to come back to my box, check the new password, go to the other room and try again to log.
When in my house, that dumbness is just frustrating, but imagine I'd be to the other side of the world....
So, is that a bug ?
Hi @marcusus
I recommend to add a permanent password for unattended access or set up easy access.
In this Knowledge Base article, you can learn how to make the setup.
I hope, that helps and all the best,
Esther
Former Community Manager
