how can i start teamviewer?
Bartimaeuseyes
Bartimaeuseyes Posts: 15 ✭✭
team viewer will not start icon keeps rotating it never gets past here.
  • Bartimaeuseyes
    edited April 2023
    i have not changed anything except Linux Mint updates, perhaps there is a new conflict with the updates?
  • lepingouin
    lepingouin Posts: 6 ✭✭
    Try to restart your daemon:
    sudo systemctl restart teamviewerd
  • Bartimaeuseyes
    edited April 2023
    nope, that changed nothing, circle dots keep spinning. i even deleted and re installed, still no change
  • lepingouin
    Try this command:
    sudo lsof -n -i TCP|grep teamview
    Should return something like:
    teamviewe   1975           root  12u IPv4  40913     0t0 TCP 127.0.0.1:5939 (LISTEN)
