Install Limit Reached - login issue
RuizAero
RuizAero Posts: 1
edited July 2022 in General questions
When trying to log in I receive a message of "Install Limit Reached"
When I check my account Settings /License it is indicated 3 detected / 9 available installations. So I don't understand what is wrong.
I had before 9 computers without problem. Has the number of active computers changed to 3 now ?
  • JenW
    JenW Posts: 981 Moderator
    Hi @RuizAero,
    Welcome to the TeamViewer Community! 🎉
    If you received the message about the "Install limit reached", that means that the device is not known within your 3 licensed devices.
    With your Business license, you can have up to 3 devices on which your are logged in with your TeamViewer account. If you need to change one or several of those devices, you have a limited number of changes: 9 in your case.
    You can find more information about it in our dedicated article: 👉 Activation management
    If you have any difficulties to change your devices, just let me know 🙂
    Jennifer
  • david_hj
    david_hj Posts: 1
    the link is broken.
    also, i only have 1 detected / 2 available installations. and i'm using a free version. what's going wrong?
  • JenW
    Hi @david_hj,
    Welcome to our Community! 🙌
    A small hiccup occured yesterday to access our Knowledge Base. It is now resolved so you should be able to access the article mentioned above.
    However, in your case, as a free user, you have now the possibility to assign up to 3 devices to your account. To know more about it, please check out our dedicated article: 📄 Add a new device to your account
    If you have further questions, let us know!
    Jen
