I have same issue since Yesterday. "Enter" keyboard Key doesnt work / has disappeared since 2 days.
Version 15.53.452
Redmi note pro +,
Android 13,
Connecting to windows 11
I am seeing this again the last few days.
Android 13
Pixel 6A
Connecting to windows 11.
Works OK now, TeamViewer 15.43.198 for Android connecting to TeamView Host 15.42.6 H for LInux.
15.42.7 H for Linux is also now available and works OK.
TeamViewer for Linux now at 15.42.6 H and still a problem
Mine is also still non-functional after the update to TV version 15.42.169 CL
Still a problem with connections from current version of TeamViewer for Android 15.42.169 CL to TeamViewer for Linux 15.42.4 H
Apparently it's been delayed. My support ticket updated with the following:
"We have confirmed with development that the main release has been set up for Tuesday June 27th in the morning hours.
We apologize for this new date. I will leave this ticket open to gather your feedback on the new update of the app. "
Still no new android update - last from 6.06.2023 does not work properly.
Rocky,
In my support ticket, TeamViewer said they'd be releasing an update on June 20th, and implied that the update would contain a fix for this issue. They recommended "removing the app >> rebooting the device >> install the latest release on June 20th". Hope that helps!
I am having the same issue, I can't use ENTER key either. Anyone have a fix for this issue?
Yes, same issue, I can't use ENTER key on Command Prompt recently, very hard for me to remote support when using Android device.
I have the same issue after upgrading Andriod app. But strange: it does not work on Windows cmd.exe or this very comment window, but it works in e.g. Notepad or Notepad2 :?
Host Windows 10 v15.42.5 (latest), remote Android after upgrade v. 15.42.160 CL
Please fix :)
I have this issue too now. The enter/return key in the on-screen keyboard does not work as of this morning, presumably after the most recent update installed. I've restarted everything, checked the keyboard settings, and reinstalled the app to no avail. Help!
