I have a license of TeamViewer 10.
Is Windows Server 2016 supported on TeamViewer 10?
Hi santai,
Windows Server 2016 is compatible with TeamViewer 11 and upwards. TeamViewer 10 is not officially supported on that operating system.
If you encounter any technical problems on your Windows 2016 servers, we would therefore recommend updating your licence in order to make sure to have the best possible performance.
I hope this information helps.
Katharina
Hi Katharina,
I understand perfectly.
Thanks for your help.
