Replaced laptop - cannot add as device
I just replaced one of my laptops, and I signed in and tried to add it to my managed devices so I can access it remotely, but when I click "Add device", it says "Active", but this laptop does not actually appear in my list and I can't connect to it from my other laptop. The laptop I sent away for repairs still shows in the list, and I can't delete it, and I'm wondering if it somehow things the two are the same?
How do I fix this so that my old laptop is gone, and my new one is accessible?
Hi @ZenHands,
Thank you for your message. 🙌
I don't think that the system thinks both devices are the same, as each device has unique identifier metrics.
My assumption is that the device is assigned to a different account or that it's just a bug that you don't see it in your list.
What you try is unassign your device and assign it back again.
To unassign it, go to the Device's settings ➜ Device management and untick the toggle.
Now it's unassigned, go back to your Device list, click +Add device, Set up remote access on this device, and check if the device is now visible in your list. 🙂
/JeanK
I had the same issue and it was resolved.
