Error:Partner did not connect to router
blinky
blinky Posts: 1
Everything has been working finr for weeks but tonight I keep getting the error 'Partner did not connect to router'.  The laptop is outside that Im trying to connect to and I have confirmed it has internet access ok.  I have tried with a PC and my Android to connect to the outside latop but keep getting this error - any ideas?
    Hello @blinky,
    I recommend you to restart the TeamViewer service on your laptop.
    -Execute run, type services.msc and press OK
    -Now find TeamViewer, and restart it by doing a right-click.
    Then, restart the TeamViewer application. It should work again.
  • Dfinston
    Dfinston Posts: 2 ✭✭
    edited July 2023
    Getting the same error. help
    Tried everything. Used **Third Party Product** and **Third Party Product** to see if router working and if Teamviewer got inadvertantly deleted .. It did not not.
    I need to be able to use my full program that I want to use is Team Viewer.
    no connection to partner.
    partner did. not connect to the router
    error code: waitforConnectFailed.
  • Dfinston
    also in my icon for remote commuter it shows. red box. yet in the other 2 computers for team viewer- don't see any red box. What is up
